Is it possible to make a layout with flexboxes in the mask mode slides, so that when you create a new slide (from the mask mode slide with flexboxes), the flexboxes can be edited, modified, etc.?
If so, how do you do it? Is there any special setting to do?
“Mask mode” here seems to be similar to Slide Master in ActivePresenter:
However, it’s important to note that when using Slide Master, any content added to it will be combined with the slide background unless you add placeholders to hold it.
So, yes in this case you can add a flexbox placeholder to a silde layout in Slide Master.
