Good morning, everybody!
I would like to know if there is a possibility to enlarge the boxes to be filled in “Fill in blanks question”
Thank you in advance for your time. ![]()
There is an option in Properties > Answer Style > Box Width but I am not sure it is what you are looking for or not.
Thanks for your answer!
In the properties I do not see this setting. There’s only the one to resize the mother box…
I’m interested in enlarging the one marked by the arrow in the first image…
Hi, Toan,
but there only changes the edge of the big window, I needed to change the size of the boxes where the text will be inserted by the students…
Is that possible?
Did you take a look at the screenshot I attached?
Box Width property indeed changes the with of the text entry boxes.
However, all text entry boxes will have the same width.
Regards.
Si’, ho visto Toan… Questo è il mio schermo di visualizzazione…
Ma forse non ci capiamo… Vorrei ingrandire questa finestra…
Grazie mille e mi dispiace di avervi fatto perdere tempo…
You need to expand Answer Style section to show Box Width property.
You’re an angel Toan… and I’m blind…
Thank you so much.
