Feature Request: Allow Custom Output Filename When Exporting SCORM Packages
Hi ActivePresenter Team,
I would like to suggest an improvement to the SCORM export workflow.
In the Export to SCORM dialog, under Operation Modes, there are several options such as Test. When I select the Testmode, ActivePresenter automatically generates a package named test.zip.
It would be very helpful if there were an additional field allowing users to specify a custom output filename before exporting. For example, instead of always generating test.zip, I could enter a name such as Mat_v1.zip and have the package exported with that filename.
This would be especially useful when testing multiple versions of the same course. Currently, I need to manually rename test.zip in Finder after every export, which becomes repetitive and time-consuming.
Adding a custom filename option would make version management and testing workflows much more convenient.
Thank you for considering this suggestion.
Hi Alice,
Thank you for your suggestion.
We appreciate you taking the time to share this idea with us. We have forwarded your feedback to our development team for consideration in future improvements.
Best regards,
Hoa
Hi Hoa,
Thank you very much for your response and for forwarding the suggestion to your development team.
Best regards,
Hi Alice,
We would like to let you know that the feature you requested has now been included in ActivePresenter 10.6.0.
Please update to the latest version and give it a try.
Thank you for your feedback and for helping us improve ActivePresenter.
Hoa
