Problem: EYEDROPPER NOT WORKING SINCE UPDATE 3.1.0 IT- ALWAYS CHOOSES BLACK
Saola Animate version: 3.1.0
OS: WINDOWS 10
When I click on the eyedropper and pick a color from another element on screen (yellow for instance) it chooses black every time, will not choose any other color, I can only change the color by NOT USING the eyedropper and directly clicking with mouse pointer on a color sample in the color palette.
Are you using multiple displays?
If so please move Saola Animate window to your primary display to overcome the issue.
I’m sorry for this inconvenience.
I am using multiple displays. I had actually already tried moving Saola to the primary monitor, but when I do that and then use the eyedropper, it crashes Saola. I am still able to just use mouse pointer and choose a color from the palette but having the eyedropper is very useful for duplicating the color of something on screen, hope you can fix it soon, wow, never realized how often I used the eyedropper.
I to use the colour picker all the time but I also have a windows tool that does the same job as I need to pick colours outside of Saola for use in a project. It’s called PicPick and might help you whilst Atomi fix the in-built one.
I also use a trick for managing colours that I use regularly, and across projects. I create an on-screen colour palette with the colour and hex code, then just use Saola’s show across screens option. Leave it just outside the scene or use a bit of CSS and it won’t appear in the published project.
Hi mackavi, that is a really cool trick, great idea! I was trying to do something like that a while back but it never occured to me to use the show acress screens option, thanks for sharing it, and that PICPICK program is nice.
I have one other color picker I have been using for a while, called Instant Eyedropper, when you run it, it sits in the task bar and you left click and keep holding left button down as you drag mouse pointer to the color you want and when you release the mouse button it copies the color code # to the clipboard.
