Problem: How can I export presentation to LMS Moodle different than activepresenter.online?
ActivePresenter version: 8.1
OS: Windows 10
OS: Windows 10
Hi Robert,
https://activepresenter.online/ is based on Moodle with some customization for integrating with ActivePresenter. So you cannot publish to other Moodle LMS than ActivePresenter Online.
Hi Nam,
I found on page 400 of ActivePresnter User Manual following text: “Other than ActivePresenter Online, you can also publish your course to another LMS site by clicking the LMS site button. Please be noted that ActivePresenter can integrate with LMS using Moodle and you need to contact us for integration.” This is why I wrote to you. Should I understand that only possibility is manual export of SCORM package?
Robert
Hi Robert,
Yes, you are right. We have a Moodle plugin which is used to integrate with ActivePresenter. However, it is not ready to public yet.
You wouldn’t possibly have a plugin for Blackboard integration as well, would you?
Hi Roxie,
Unfortunately, we don’t have planing to support Blackboard integration yet.
Hi Nam,
Has the Moodle plugin been released? If not, is there an ETA on it?
Thanks,
Scott
Hi Scott,
Since there are not many user requests for it, we don’t have an exact plan yet. We will inform you when it is available.
Thanks for the reply, Nam.
Best,
Scott
Any update on this Moodle plugin release ETA? Thanks!
