Yes indeed it IS more powerful that I expected. I’ve just spent the afternoon working through your YT tutorials and I am extremely impressed. I am an ex Hippani user and it’s not being actively supported anymore. I will be buying a copy of Soala.
The only hiccup is my JavaScripting skills not being very strong. Do you have a list of resources like button scripts etc that can be essentially cut and pasted then adjusted to fit custom projects? i’ve been through this forum searching for code snippets, specifically drag and drop functions but I can’t get them to work when pasted into Saola. I am just looking for a simple Drag and Drop that does not retract back to it’s position if not placed in a specific position. Just a simple “Drag an Object around” function?
Many thanks
Deek
