I have made substantial changes to the slide layout and Player settings in a particular presentation and I would like to add these back to the template so that the new design can be used elsewhere.
Is there a way to export Template & Player settings from one presentation and import them into another?
You don’t need to export or import the template and the custom settings in Player Settings, you just need to save all the settings you made as a custom theme.
By doing so, you can reuse it across projects later on.
For detailed instructions, kindly watch this video tutorial:
