It would be helpful to implement actions before, during and after end an object animation, for example: when a text animation ends it enables the next button.
Thanks.
Thanks.
Hi Juan,
You can consider doing two easy ways below enables the button when the text animation ends:
Hope that it helps.
The main reason to request events triggered by animations is that I have a Next button desactivated always available to make click but only activates when the slide is viewed completely and change a variable to true, and if the user want to go back to viewed slide be able to make click to Next button inmediatily whitout have to view it again from begin.
This is just an example, but it would be useful to many things, and not only to text objects.
Thanks.
Hi Juan,
Thank you for explaining your idea clearly. We’ll consider implementing it.
What do you think about adding action to the timeline as timeline triggers in Saola Animate?
Please refer to this article for information: Use Timeline Triggers in Saola Animate 3 - Atomi Systems, Inc.
Looking for your follow-up.
Hi, Thuy,
Both features are awesome, while events triggered by animations are useful to have control to before, during and after animation is finished (actions), the other one have control to the animation itself (keyframes).
I hope you can implement them.
Thanks.
