Allows us to use Save As but all images are missing, images added using image fill. we recreate/add images and the same error occurs.
We also get an error project is corrupt
ActivePresenter version:
Pro Edition
Version 8.5.8 - 64-bit build. (Released: 2022.07.28)
Thank you for sharing the log file of ActivePresenter.
After taking a look at it, we found that your issue may happen because you saved your project on the network drive.
To avoid issues the next time, download projects to your computer before further working with them.
I have experienced this exact issue today. i transferred the file over to my C drive and it wouldn’t even open. now I’ve copied the file back to a network drive. all the imported images have been removed.
this has been happening for some time now. why would the images be missing? are they saved separately to the approj file?
It seems that your project is corrupted due to transferring file to the network drive.
For further analysis, please send the log of ActivePresenter to support@atomisystems.com.
You can follow the path or watch the quick video mentioned in my previous response.
