If I selected multilayers with CTRL + mouse … I don’t get all selected all … some are not selected and some if … I would like you to correct this error.
Hint: If selected multilayers and groups you can enable / disable and lock once for all selected
Hi Casimiro,
In Timeline or Elements pane, Ctrl+mouse click will not work with a group if that group has at least a child being selected. However, it will work when you select on Canvas.
Lock/Visible feature is not applied to all selected elements but only the one is clicked.
We’ll try to improve these features in the future release.
