sthradh
(Ednaldo)
1
Problem: Hello, I have a problem, when starting the program the following error appears, can you help me?
ActivePresenter Version:
OS: Win 10 pro
Notes: Error is in portuguese, the translation is: activepresenter object doesn’t support property or method
phuongdv
(Dao Viet Phuong)
2
It seems the issue happens on some specific computers. You can safely ignore this warning by following steps:
- In Start Page, click Preferences (the Gear icon).
- Select the Miscellaneous tab.
- Set the Log UI Level to Error.
- Click OK and restart the program.
