Problem: I am using Poppins font, loaded it into Saola using Google Fonts, and I have checked the Embed System Fonts box. My exported project works great on PC and the font appears as it should. However, when the project is loaded on an iPhone, a default font like Times New Roman appears instead. What can I do to fix that?
Let me clarify for you some information.
Google Fonts are fonts that are loaded directly from the Google font server.
The Embed System Fonts feature is used to embed the user’s machine’s fonts that are used in the project. So, you don’t need to select this checkbox if you use Google fonts.
We tested this case and see that everything works ok. Please take a look at the image below:
