Edit or Customize Column Headers on Reports Slide
Good day, all!
I’ve been looking at adding a reports slide to a quiz and really like that I can show and hide a lot of the information available and while I also like the detailed results area, it has a bit too much information.
Fortunately I found this post where @PhuongThuy_Le explained how we can hide specific columns…great stuff! I wonder, though, is there a way to customize the column headers with code? For example, the first column header is No., but is there I way I could change it to say Question Number, or instead of Slide Index change it to Slide Number for example?
I asked this on the thread in the referenced post, but in case it got buried in the old conversation, I thought I’d start it new here.
TIA!
samamara
Good morning @samamara,
Please try adding the scripts below to the Report Slide’s On Load event:
var columnHeaders = { // index : label
    1: 'Question Number',
    2: 'Slide Number'
for (var index in columnHeaders) {
    $('table th:nth-child(' + index + ')', this.node).text(columnHeaders[index]);
Then, edit more at columnHeaders to display as desired.
BR,
Thanks so much @PhuongThuy_Le! I was able to use this to do exactly what I wanted and I was able to combine it with the code you gave on the other post to both limit the number of columns and rename them a well :folded_hands:t2:
Thanks again!
Thanks for getting back to me, @samamara
That’s great to know that it helps :slight_smile:
