Hi, it’s a pretty common feature in any other eLearning software to allow the teacher/student to draw (some allowing multiple color) on the slides. Example like tracing a letter for a learner.
Can it be done in ActivePresenter or is there a workaround to achieve the draw effect in the html5 output? Thanks!
Yes, Please! I would find it very useful when teaching if I could highlight, draw, and annotate on the presentation itself. I would definitely be using the program even more than I am now.
We would like to extend our sincere appreciation for your interest in ActivePresenter.
Just wanna let you know that we have considered the feature request you mentioned, and we understand how important it is to you.
While we don’t have an exact plan to implement this feature at the moment, please rest assured that we are continuously evaluating and improving our product to meet the evolving needs of our customers.
Thank you, guys. And if you have any further suggestions or feedback, feel free to reach out to us.
If you are looking for a simple and quick solution (only supports line drawing), please check the following sample project: CanvasDrawing_2.approj (304 KB)
You can apply this solution for your project with simple steps:
Open the sample.
Go to ActivePresenter > Project > Properties > Interactivity and copy the JavaScript action into your project.
