Please add a Drag event, to enable dragging an object on screen.
Better still, it would be great to have the drag control the timeline (like in Tumult Hype).
Hi Moshe,
Thank you for your suggesion. It’s already in our TODO list.
Thanks.
… and congratulations on Version 3.0
Hello, thanks a lot for V3.0. Unfortunately I can neither find drag events nor touch events. What am I doing wrong?
Due to some technical limitations, we can’t manage to make this feature available in version 3.0.
We’ll try to support it as soon as possible.
The “Control animations” sample in Samples page of the welcome screen in version 3 shows how to scrub the timeline using a custom element (the slider) and JavaScript API.
Could you please provide a link to “ The “Control animations” sample in Samples page of the welcome screen in version 3” that you mentioned.
I can’t seem to find it.
Thanks.
