Drag and Drop Question, advanced functionality
I created several drag and drop questions for a serious game (cf attached file).
test.approj (3.1 MB)
Everything runs smoothly, however, I would like the drag and drop question to retain correct matches and reset wrong ones when pressing Submit.
What is in your opinion the best way to go about it ?
You can edit the second slide as you wish for demonstration purposes.
BR,
Marco
ActivePresenter version: 9
OS: Windows 11
Please find the attached project for more details. In this project, I’ve adjusted one drop target as an example for your reference. Slide 2 demonstrates a normal action, while Slide 3 shows an advanced action for faster creation.
I’ve also set up a variable for each drop target. When the drag source is correct, the value is set to 0; when it’s incorrect, the value is set to 1.
test (2).approj (3.1 MB)
Hope this helps!
