Hey every one! Here is a question:
In interactions-drop area there are option show correct or incorrect block after dropping right or wrong element.
But in questions drag-and-drop there is only one option show feedback layer
Is it possible to:
Then student DnD correct elements and hits submit near each drop zone shown red cross or correct green check-mark?
Also there are buttons with 2 states innocent/guilty and the only one is guilty it also should be checked after hit submit button
You can use built-in correct/incorrect checkmarks in ActivePresenter to show. Just add the Show Responses action to the On Click event of the Submit button like this:
Also there are buttons with 2 states innocent/guilty and the only one is guilty it also should be checked after hit submit button.
I’m not sure about what you want to achieve? Please describe in more detail?
I’ve already tried correct/incorrect marks but they double shown on drop zone and drop object like bubbles with no option to change their size/color/place
What I need: in my sample near each drop zone there are 2 invisible elements green and red. After participant made all his decisions hi hits submit and sees which of them where right in each group of character eg:Emma CLUE 2 / MOTIVE 3 / INNOCENT
Btw is it possible in active presenter making drag item with fixed direction? E.g. like only up or down? In some programs there are option like as control time line - that means that animated item doesn’t move at all it only moves then user drags it and it moves only on specific direction
I have found epic problem:
When I’m making objects with actions and variables it works perfect inside 1 slide
But if I want them showing on multiple slides MOSTLY all actions and variables just disappearing - could it be solved somehow?
Thank you for reporting the issue, we’ll fix it in the next update.
In the meantime, please show objects over multiple slides before adding actions to them.
We’re sorry for this incovenience.
Furthermore, please note that objects showing over multiple slides don’t support some actions. For example, they can’t show/hide/change state of any object in a certain slide. Those actions will be removed from the object you make it to show over multiple slides.
