Currently, if you select multiple resources in the resource pane then export them all at once, a dialog asking you to select the file format pops up during export for each resource.
Because of this, if you are exporting, for example, a lot of large videos, you can’t start it then walk away: You have to keep watching it to answer each dialog that pops up. This is a big workflow time sink for time-consuming exports.
It would be nice if, when multiple resources were selected, you were asked to choose the file format at the beginning of the job, and never asked during the export operation itself. This way you can get everything started and go do something else, and it will finish on its own with no interaction.
Thanks!
