I have to create new interactive presentation where I want to display slide-in-slide. Contents:
I have workflow of three steps on slide 1. Let us assume each step has 4 slides (slide 2-5, 6-9, 10-13). Now, On slide 1, I want to show on mouse roll over - display 4 slides in a pop-up one-by-one. May be it will have audio too. Same follows for rest of the steps too.
I’m not sure if I understand your question correctly but you still can record video and use events - actions as mentioned in my previous answer to create the effects/ interactivity.
Yes sure. your solution is a partial solution to. I appreciate it. But want to explore if we can go one step ahead in terms of interactivity and intuitive presentation.
Is there any possibility to use JavaScript to show preview of 4 slides one-by-one. Can you help me with that?
