Saola Animate version: v3.0; OS: Win 10; One bug found!
Any of three cases above cannot input number any more!!
Best regards,
Afei
Best regards,
Afei
Hi Afei,
You need to select/detele the number before replacing it with another one (double click the number, for example).
I recommend you report this as a bug, seriously. this is not a normal case.
I think your company make a high-end software, not a low-end,
as a conscience advice from a old programmer.
regards
Hi afei,
The Diameter is limited within the range 50 - 400. It doesnāt allow the user to input a value out of this range. When the current value is 100 or 150, typing one more digit will make the value greater than 400 so itās not possible.
We know that it is not good for user experience but itās the behavior of the UI control in the framework used to develop Saola Animate.
It should limit the value only when the user completes typing (e.g. pressing Enter, focusing on another controlā¦). Weāll try to improve it this way.
ToanLS,
Thank you for your high level reply
thatās what I want to know.
From the programmerās standpoint,
restrictions before input are the simplest and most effective.
with my idea, I could replace ā5|0ā with ā|0ā to avoid over range,
where ā|ā stand for userās input (if it is possible to over my range).
About the userās experience, Yes,
because the text box control is a beginnerās level practice,
so I am surprise to see this on a āleading softwareā.
Also, Iāve post two more article about UI design
They all mean the same thing, ālet user know where they areā.
Hi afei,
Thank you for reporting bugs and providing suggestions for Saola Animate.
I canāt make promises on how and when they should be fixed/improved but please rest assured that we note and consider any user feedback.
