I would like to customize the bullet point in text. That is possible in PowerPoint presentation but while importing or editing in ActivePresenter only are able some simple bullet points.
Thanks.
Thanks.
What sort of customization are you thinking?
Some ideas
Yeah it is a little more work but gets you where you are headed in the short term.
Hi @JuanD18,
At the current time, ActivePresenter supports some simple bullet points as you can see.
We’ll consider adding more if there are many other requests.
In the meantime, you can try the Greg’s suggestion.
BR,
