is it possible to have the mouse pointer as in the attached photos in active presenter?
Yes, of course!
Select the Cursor and look for Cursor Image property on the Properties pane then you can change the cursor image by selecting from external image files. Cursor image can be in PNG, JPEG, BMP or GIF, but you should always use PNG where possible.
but with the mouse button used the image changes by itself?
What do you mean, Andrea?
