Cursor-sample order or flags are invalid
I used the video recorder feature and pause the recording to start it again. When i finished the recording and ended it, there was a problem with the cursor path : it couldn’t save it.
And indeed, there was no cursor path in the video.
I changed the hotkey for the pause, and in my other videorecording where I didn’t use the pause, the cursor was present.
Lucie
ActivePresenter version: 10.6.1
OS: windows
Hi Lucie,
We’re sorry for the inconvenience, and thank you for reporting this issue.
We’ve fixed it in this test version. Please download it and let us know if the cursor path works correctly.
BR,
I tried the test version and it works perfectly.
Thanks !
Lucie
Great, thank you for confirming!
You can continue using this test version until the official version is released.
