Hello, I’m using AP8 in Dark Mode. As you can see it’s not easy to see which slide I am currently on. The Blue highlighting is not very visible on the dark background.
Would it be possible to change the blue highlighting of the thumbnail to yellow when the user chooses dark mode?
Thanks for your feedback. We will try to improve this in the future releases.
To overcome the problem, you can edit the file at C:\Program Files\ATOMI\ActivePresenter\themes.config. You should open the file with Notepad and change the value like the below image:
