Problem: How to problem: I would like to set up 2 attempts at a question with the following characteristics
If correct on first attempt, full points (say, 2 points)
If incorrect on first attempt show hint (incorrect msg 1) and redisplay for second attempt
If correct on second attempt, award half points
If incorrect on second attempt, show answer (incorrect msg 2) and move to next slide
I understand how to set up a single “incorrect” message, but not a separate one for the second incorrect attempt. I kow how to set for two attempts. I know how to create the messages in the feedback master and call them.
I do not know how to get different messages for each attempt or how to reduce the points if correct the second attempt.
In looking over your solution, it makes total sense, except I haven’t figured out how to pass the value of the variable points to the apQuizScore. The latter isn’t available from the drop-down in the Adjust Variable interface so I’m assuming it cannot be adjusted. So how can I get the apQuizScore in the report slide to reflect the point value of the variable points?
I know I can just set the field to %points% in the report slide, but that may open a whole new can of worms in scorm reporting if I add that later. It also means changing a lot of other variables in the report slide.
Can you please let me know if you only need the apQuizScore in the report slide to reflect the point value of the variable points?
Is it necessary to show the score of each question in the detailed report?
In the latter case, we can’t guarantee if the app can support.
No I don’t need each questionscore, just the apQuizScore. I’m just trying to get te overall score in the report slide to match the Points from the solution you gave. Although I haven’t yet studied how to integrate the scores with an LMS, I’m thinking this might be necessary to pass the score to the LMS if needed.
Thank you. That makes sense. I saw that variable in my version but wasn’t sure how to use it. There was no mention of it in the documentation for that version. I will upgrade and use i. This looks great.
