When i import powerpoint slides in project .it crashes and gives error. I have just updated to activepresenter 7 …and the problem is there…plz.resolve this issue as sooon as possible otherwise i have to use its older version…this is a screen shot of error that i am facing???resolve it …
Can you please tell does the issue happen when importing every presentation or just a specific one? If it only happens with a specific presentation, please share it so we can check. You can drop an email at support@atomisystems.com
It happens with every file …1 tried it with 4 files…
Can you please help to check with the temporary fix at https://drive.google.com/file/d/1A65Q5b-zyNwsk4qsowKsfYymeqGrbPGy/view?usp=sharing
How to check this???
The issue should have been fixed in version 7.0.1. Please download it from our download page at https://atomisystems.com/download and try again.
Ok…thanku for your time
this errror came whenwhen i open the project …even i have uninstalled activepresenter and reinstalled it…even then the error continues…
Does the issue happen with every project or just this one?
