When sending a report I get a popup saying
“could not send report to http://192.0.2.10/reportreceiver.php:error”
ActivePresenter version: 9
OS: Windows 11
The php script has successfully run and captured the report.
(I used the sample php script from the user manual)
I tried adding an exit(0) to the end of the script but that made no difference.
I’ve tried using both chrome and firefox.
A packet capture shows a 200 OK from the HTTP
Chrome debug console shows some kind of access error and then
POST http://192.0.2.10/reportreceiver.php net::ERR_FAILED 200 (OK)
It appears to be something to do with Cross Origin Resource Sharing (CORS)
but I don’t know enough to be able to fix this.
My PHP script is running in a stock docker container from the docker hub.
php:7.2-apache.
Could this be a deprecated feature issue?
I note that the chrome debug console says:
“a deprecated feature has been used: Affected resources rlplayer.js:101”
