I’m working on a series of projects in ActivePresenter, and I frequently need to reuse certain elements between them. Recently, I had two projects open at the same time. In one of them, I revised some logic and consolidated it using Advanced Actions (JavaScript + event handlers).
However, I noticed that I am unable to copy Advanced Actions from one project and paste them into another, even when both projects are open simultaneously. This makes it quite time-consuming and error-prone to manually recreate the same actions in each project.
Is there a recommended way to copy or export/import Advanced Actions between projects? If not, is this a feature that could be considered for future updates? It would greatly improve workflow efficiency when working with multiple related projects.
Thank you in advance for your support!
ActivePresenter version: Version 9.3.0 - 64-bit build. (Released: 2025.04.08)
OS: 15.3.2 (24D81)
Notes: Best regards,
