Hello.
It would be really helpful to be able to Copy & Paste in place. Currently, when a paste is made, the object shifts from its origin.
Thanks
Hello.
Thanks
When you paste an object, the newly pasted object will be near the original one.
This prevents the new object from overlapping the existing one. ActivePresenter is designed to work that way.
If it’s not your case, could you please send a screenshot or a video to illustrate the issue?
Tuyen
Hello.
In our modules, we use an information bubble which is duplicated several times in the timeline.
So we do a copy / paste but the pasting is shifted each time.
This forces us to reposition all the bubbles manually.
We have modules that are several hours long, I let you imagine the number of bubbles that must be repositioned.
Many software have a keyboard shortcut to copy / paste it in place (Adobe Animate, Storyline, …)
Thank
We’ll consider this feature if there are more requests from users.
At this time, you can copy and paste as many bubbles as you want and set their position at once.
Tuyen
