Hi, I can’t seem to figure out how to play the SAME AUDIO (1 audio) over multiple scenes.
How do we do that?
Thanks,
Steffen
How do we do that?
Thanks,
Steffen
Current version of Saola Animate doesn’t support it directly from the UI. We’ll consider implement it in future releases.
In the mean time, please take the following steps to play an audio over multiple scenes:
if (!doc.myAudio) {
// replace song.mp3 by the audio resource name
doc.myAudio = new Audio('resources/song.mp3');
doc.myAudio.loop = true; // remove this line if don't want to loop
doc.myAudio.play();
Please note that this method only works when exporting to HTML5, doesn’t work when preview (because the url to the resource is differerent).
Regards.
How can I use the same function to later stop the track playing?
Cheers
To stop the track playing, please use the following code:
if (doc.myAudio)
doc.myAudio.pause();
What function can we use to fade out over 3 seconds rather than end abruptly?
Thanks!
Hi Shawn,
You can use Volume animation to fade out the audio.
However, this audio element is created by coding, so fade out also requires coding:
function fadeOutAudio(audio, duration /* in ms */) {
var initialVolume = audio.volume || 1;
var startTime = Date.now();
function fadeOut() {
var elapsed = Date.now() - startTime;
if (elapsed >= duration) { // complete animation
audio.volume = 0;
return;
audio.volume = initialVolume * (1 - elapsed / duration);
animationId = requestAnimationFrame(fadeOut);
var animationId = requestAnimationFrame(fadeOut);
To fade out your audio 3 seconds: fadeOutAudio(doc.myAudio, 3000);
2 Related questions:
Thanks!
If you want to do this in JS, then there are lots of existing libraries for it - just google JavaScript Jukebox.
The whole reference for creating your own is here: https://www.w3schools.com/tags/ref_av_dom.asp
But you may want to look at Taonis’ answer to your previous question - Objects / Button across Scenes
You could create a jukebox as a symbol with the audio tracks on timelines and use this method to add it to all pages for continuous audio.
Excuse my ignorance, but I’m not great with JS…
Where would I paste the code
if (!doc.myAudio) {
doc.myAudio.play();
Would it for example be in the HTML file, or one of the JS files once I’ve exported to HTML?
Could you give me an example?
You probably want to add it to the first scene that needs the music to start.
With the scene selected, in the scene panel click the event handlers button:
In the window that pops-up, click Scene Activate > Other Actions > Run JavaScript
When the action is added, click the Params selection and choose Add Function:
When the Script Editor window loads, paste the code between the lines:
Ahhhh fantastic! Thanks so much, never thought of that
