Alla fine del nostro corso/presentazione abbiamo inserito 10 domande test finali (con 10 punti ciascuna).
Sarebbe possibile far si che, se lo studente non supera la percentuale del 70% di risposte esatte si torni alla domanda n° 1 e rifaccia tutte le 10 domande?
Se invece lo studente supera la percentuale del 70% di risposte esatte, andare alla slide successiva alla domanda 10 ovvero la slide finale?
Potete aiutarci?
Grazie mille
ActivePresenter version:
OS: Windows 10 Home
Notes: ActivePresenter Pro Edition
Versione 9.0.4 - 64-bit build.
Here are the 2 main steps to achieve what you want:
If the student does not exceed the percentage of 70% of correct answers, he returns to question No. 1 and does all 10 questions again.
=> Set the Pass Condition in the Export to HTML5 dialog as below:
Add events - actions using the apQuizScorePercentage condition to go back to question No. 1 if learners don’t pass the course. Otherwise, they will go to the next slide.
Please take a look at the attached sample below for more information. course completion settings.approj (856 KB)
This sample consists of 10 questions from slides 2 - 11. In step 2, I add events actions to the Continue button of the Correct and Incorrect Feedback Layers in Feedback Master:
