Is it possible to change the color of the Audio Player?
As far as I’m aware, not consistently across browsers. There is a webkit css selector that works on Chrome:
audio::-webkit-media-controls-panel{
background-color:blue !important;
But if you want it on all browsers, I believe you have to build your own custom player.
Hi mackavi,
1.Thanks for the input will give it a try. I am now wondering if the “HTML” widget could be used and input the code of a free html audio player into the widget.
- Also, since we can edit the html of the Saola Animate Document, would it be possible to insert the code of a free audio html or java player straight into the document?
Hi Locky,
A custom media player usually includes both JavaScript and CSS. The common steps to use it with Saola Animate are as follows:
- Import the media player JavaScript and CSS to Resources pane: https://atomisystems.com/html5-animation/using-external-javascript-css-html/
- If the player allows changing styles via CSS, you can edit its CSS file in step 1, or add your own CSS file to override some player styles.
- Add your own Run JavaScript action to initialize/create the player in Scene Activate event or Document Ready event. Where and how to add this script depends on that specific player library.
You may need to assign a class name for your audio elements or use the following Saola Animate APIs in this step:
doc.getElement('audio element name').dom // containing tag of the audio element
doc.getElement('audio element name').mediaDom // the audio tag
Hi ToanLS,
Thanks for the reply, I will give it a try and see how that works. I am not the smartest at doing these things, do you by chance have an example Saola Package example showing this?
Yesterday tried this ----> I downloaded a free html5 player from wimpyplayer.com and uploaded the html player file and the folder it came with to the root folder of my website. Then I put an html widget on the page of my Saola Animate project and entered the url of the Wimpy html player page, and it worked like a charm! And being a widget, I can move to any position.
I am curious though, if doing this the way you are describing, would have benefits that I can’t see because of my lack of experience? (Maybe a widget is not the best way to go).
Hi Locky,
You can see the Saola package sample that uses Green Audio Player here: custom audio player.saolapack (40.1 KB)
The player is initialized in onSceneActivated function. If you use another player, you need to see its manual or examples to update the script.
Using a custom player this way allows you to change other properties of the audio element directly from the UI, e.g. element size and position, audio resource, play/pause audio using built-in event-actions…
Hi ToanLS,
Thanks for the saolapack example, will take a look tonight can’t wait to try it!
