I am working a lot with grouped objects. They are also shown grouped in the timeline, however, it seems that there is no button where I can collapse a “timeline group” so that it is displayed only in a single lane?
If you want a group object in the Timeline pane to display in a single line instead of multiple lines, in the Timeline pane, right-click the group object, deselect Show Child Objects.
Please correct me if I misunderstood your question.
Yen
Ah, OK, that worked. Thanks!
However, the option is a bit hidden. Wouldn’t it be more intuitive to add a small expand/collapse-arrow to the very left of the lanes name? This way you can also collapse the items individually.
Thanks for getting back to me.
We’ll consider it, thanks for your suggestion.
