Problem: Can’t add closed captions (CC) in Saola Animate
Saola Animate version: 3.0.1
OS: Windows 10
Notes: I want to add CC to videos and import into activepresenter, or create interactive videos using just saloa animate
OS: Windows 10
Hi Sheree,
Saola Animate doesn’t support this feature.
If you want to do so, you can insert elements and use the Display On/Off and Text keyframe to show/hide and change the text.
Tuyen
