In my project the feedback slides have video, but it does not allow me to add close captions to them, it only allows me to add it in the normal slides.
Hi @junka79,
You can add HTML5 Closed Caption for the video in Feedback Master (select the video > Properties pane > Media tab > Video > HTML5 Closed Caption)
Then, select a *.vtt file from the current project , or import one from your computer . Right after that, the Choose Language dialog will appear and allow you to select a suitable language. You can add multiple closed caption files in different languages to a video.
Thank you for your help.
