Changing Text Captions by Code
Hi Friends, I woud like to know if it is possibe to change the text in a “Text Caption” by code? Or making it dynamic? If so is there any youtube tutorial for that?
Thanks!
Hi Deni,
ActivePresenter allows you to add animations for text without requiring any code, please refer to this tutorial for more information:
Video tutorials are also included in this.
Thank you hang, but what I am planning to do is this:
When I press the button, some specific Text Caption changes their text.
Here is my sample project.
changing text captions.approj (284 KB)
I tried to write some JavaScript on it, but it didn’t work. Should I use the text entry object instead? What could possibly be the problem?
Thanks
Deni
You can use the text("new text") method as below to change text:
prez.object("Text Caption_3").text("newText");
Or, use the html("newText") as mentioned in the Manual (page 328) like this:
prez.object("Text Caption_3").html("newText");
Hang
Thanks Hang, I’ll test it and feedback here later. Thank you!
Yes, It did work greatly!
Thanks for your great support. One of the reasons I use your software as reference is the great customer serrvice you bring us. I should confess that I started studying some coding because of your software and the many possibilities I can use it. Thank you, again.
Thank you. I really appreciate you taking time to express that.
Hopefully you have a nice experience while using our ActivePresenter.
Hey Hang, one more question in the same issue. I tried the code you sent me before, it work good. But when I tried to manipulate the color of the text it didn’t work. I’m am trying to use it this way:
prez.object(“Text Caption_3”).html.style.font(“white”);
Can you please tell me what is the problem here?
You can use the html method, where the text is formatted according to HTML in this case.
prez.object("Text Caption_3").html('<div style="color:white;">Text here</div>');
Additionally, I think that using Object States is another simpler approach to accomplish this.
Please refer to this tutorial for more information:
Thank you,
it did work!
Finally, I found out how to change the color of a caption_text in JavaScript.
The problem is that I only want to change the color, not the text itself.
If I use
prez.object("Text_Caption_3").html('<div style="color:white;">Text here</div>');
it overwrites what was there before. How can I avoid that?
Thanks for your help!
@Massimiliano_Notaro
Have you considered making another state with the color(s) you want and just changing the states?
Let’s say I solved it by changing the color, but I like to think that it can be done and that there’s no limit to logical thinking.
Please try using this code to see if it helps:
$(prez.object('Text Caption_3').textNode).css({'color': 'blue'});
