Koen
(Koen)
April 23, 2026, 4:21am
1
I would like to change the button action in the above example.
I only want to change the variable: ‘Attempts_Level_1’ and change it to ‘Attempts_Level_2’.
The problem is that ActivePresenter will automatically change the condition from ‘not equal’ into ‘equal’.
This has caused me so much errors.
I hope you can fix this issue. Much appreciated!
Koen
Hoanp
(Hoa Nguyen Phuong)
April 23, 2026, 6:05am
2
Hi Koen,
Thanks for your feedback. We’ve noted this issue and will work on improving it in future updates.
Best regards,
Hoa
Hoanp
(Hoa Nguyen Phuong)
June 11, 2026, 1:58am
3
Hi @Koen ,
We’re glad to let you know that the issue you reported has been fixed in ActivePresenter 10.5.1 .
Please update to the latest version to enjoy the improvements.
BR,
