Hi Bill,
You can set an id for the input field, and use document.getElementById('id of the input field') to access it. For example:
- In the custom element:
<input type="text" id="user_name"> - In an event:
var user_name = document.getElementById('user_name').value;
You should double-click the Function field, select Add Function to add an event handler, and call the normal function in the handler:
function yourEventHandler(doc, e) {
yourNormalFunction();
