Hey everyone! Im new to active presenter(mostly stay on Hype 5)
I really love of functions in AP but can’t figure out some cases:
Is it possible to save buttons (I was trying multiple questions, radio buttons and etc) states like: on 1st slide users selecting some answers (e.g from 1 to 8) then all that selected answers always shown on all other slides with already selected previously answers. No matter if they comes back to older slides? But users still possible to change that answers on any slide?
On drag and drop if I make e.g 4 “correct” from 6 answers and I want to show them through all slides but visible are only that selected 4 not all 6?
I want to make some kind of pin pad with symbols like (from 0 to 9) is it possible to make a correct order of pin code? like as 2-5-8-1?
On drag and drop is it possible to make autocheck without submit button? I mean if the order is correct autoswitch to next slide?
Is it possible to make a cipher wheel with mouse or finger?
The reason about 1 and 2 is:
I’m making a small escape room for children in Egypt theme.
They Need to decide on the 1 st screen which items they want to take for adventure: only 4 from 8. That only selected items should come through all slides of escape adventure (cause they help to solve historical puzzle)
Also The could find some items on slides and that items should be show on all slides if the pick (click) them
Could you be so kind about solution about 3 and 5?
Please download the two attached projects for your references. Q12.approj (756 KB) pin pad.approj (272 KB)
Regarding question 5, it’s quite complicated to achieve.
Hence, you can find suitable HTML/ JavaScript codes. Then, embed them using the Web Object.
Only one little thing for pinpad: I cant find operator for showing messages like as:
e.g. If pin 1-2-3-4 show message 1
e.g. If pin 3-4-5-5 show message 2
and etc
I was searching for operator if correct value= … but I don’t see it
P.S. I would like show you full escape room after it would be done if you want
Then, you need to create corresponding variable.
In the On Correct event of the text entry, you add actions to show different messages with specific conditions:
I’m so eager to see the full escape room. Please share with us and other users when you finish it !
It seems that she shared a wrong screenshot.
You should add a text variable and assign it to the text entry.
Or you can use On Text Enter event.
Please check this project: pin pad.approj (288 KB)
