Button hangs after rapid transitions between feedback layers
Problem: I have added buttons on several Feedback Layers which allow the user to jump to the different Feedback Layers when the corresponding buttons are clicked. For example, there is a “Jump to Layer 2” button on Feedback Layer 1, and there is “Jump to Layer 3” button on Feedback Layer 2, so on and so forth. I have also added a “Close” button on each layer to hide the current Feedback Layer and go back to the Main Slides. I noticed that when the “Jump to Layer” buttons are clicked in succession one after another (across different feedback layers), eventually the “Close” button of the current Feedback Layer I am at will hang, i.e., it does not perform the action it is supposed to.
ActivePresenter version: 10
OS: Windows 11
Could you please email a sample ActivePresenter project containing only the affected slides to support@atomisystems.com so we can investigate?
Best regards,
Hoa
After checking your project, we suggest trying this workaround: uncheck Blocking in the Show Feedback Layer action on all six buttons used to switch between Mind map 1, 2, and 3. Keep the Show → Hide action order and the Close button actions unchanged.
Then export to HTML5 again and let us know whether this resolves the issue.
Thank you!
Dear Hoa,
I have tried your suggestion and so far the issue of the unresponsive “Close” button has not resurfaced. Thank you and your team for your prompt help!
Best Regards,
Wei Jin
