Is there any way to get button animations to work on mobile devices? None of my pressed animations show.
If there isn’t. I can fake it using the javascript below:
var obj = prez.object(this.name());
if (obj) {
// Reduce opacity to 50%
obj.node.style.opacity = '0.5';
// Move the object 4 px right and 4 px down
obj.translateBy(2, 2);
// Wait 1000 milliseconds and move it back to the original position
setTimeout(function() {
// Restore opacity to 100%
obj.node.style.opacity = '1.0';
// Move the object back to its original position
obj.translateBy(-2, -2);
}, 150);
But if the only way to get it done is to fake it, does anyone know the appropriate way to access changes to the drop shadow in javascript within AP? obj.node.style.dropShadow doesn’t seem to be it as far as I can tell.
On the translate I’d like to make the drop shadow disappear (via visibility or opacity I would imagine), and then reappear after the setTimeout is up.
