Koen
(Koen)
1
I was inspired by the drag-n-drop example. (one of the sample projects in ActivePresenter)
When I insert a ‘Drop Area’ and set the line to ‘No-line’, the drop area is refusing the drop target
ActivePresenter Version: Required: latest
OS: Required: Windows 10
Thanhvlt
(Thanh Vo Le Tu)
2
It’s not a bug. The drop area should have fill or line value. In this case, you can set Fill Opacity value to 0.
Koen
(Koen)
3
Thanks again for the quick reply.
That’s very helpful!
