Hello ActivePresenter Team,
Description:
When enabling the option “Extend object duration to match the duration of generated audio” in Preferences → Miscellaneous, the setting is not saved. Upon reopening Preferences, the option is unchecked, and instead, “Create proxy files for high quality videos when importing” becomes enabled automatically.
Steps to Reproduce:
- Go to ActivePresenter → Preferences → Miscellaneous.
- Enable “Extend object duration to match the duration of generated audio”.
- Click Apply and close the Preferences window.
- Reopen ActivePresenter → Preferences → Miscellaneous.
Expected Result:
The “Extend object duration to match the duration of generated audio” option remains enabled as previously set.
Actual Result:
The option is unchecked, and instead, “Create proxy files for high quality videos when importing” is automatically enabled.
Additional Information:
- macOS: 15.3.2 (24D81)
- ActivePresenter Pro Edition
- Version 9.3.0 - 64-bit build (Released: 2025.04.08)
- Screen recording attached for reference.
