Latest version today has stopped my SCORM 1.2 packages working/loading up and mutes my preview courses on startup, making me miss the beginning of the auto start audio. Could you please send me the link to get back to the previous version of the software?
ActivePresenter Version:
7.2.4
OS:
Windows 7 64bit
However, it’s better if you insert a start slide which includes a Start button and set it to Continue or Go next slide.
You can control the look and feel of your start screen.
Thanks for your information. It’s strange because the mute issue should not happen with IE browser. Can you please share the project file so we can check?
Maybe your server doesn’t have the associated MIME types to support MP3 and MP4 files. I have no experience with SharePoint but the following fix is applied to IIS server which your SharePoint maybe running on. Hope it provides some ideas to your case:
Right-click the site in IIS and select Properties .
Select the HTTP Headers Tab .
Select File Types .
Under the MIME Map section, select New Type .
Type " .mp4 " as the associated extension and " video/mpeg " as the content type.
