Hi, is there a way to play an audio through JS and have the code stop while its doing that? Similarly to the ‘blocking’ checkbox in the AP UI?
Thanks, Rolf
ActivePresenter version:
OS:
Thanks, Rolf
OS:
Hi Rolf,
Please check the attached sample to see if it is what you are looking for:
Audio.approj (852 KB)
I use an interactive timeline to control playback of the audio, then add a script to start the timeline with a callback.
Thanks a lot Phuong,
your suggestion
prez.startTimeline("Timeline 1", function (){
prez.object("PlaybackFinishedMsg").show();
works fine. I would like to just have the name of the function as callback and not the whole function.
So, I tried
prez.startTimeline("Timeline 1", Message);
function Message(){
which works fine, too!
However, I would like to pass the name of the object with the callback, i.e.
prez.startTimeline("Timeline 1", Message("PlaybackFinishedMsg");
function Message(Objektname){
prez.object(Objektname).show()
Is that possible as well? I don’t get it to work …
Thanks, Rolf
Hi Rolf,
The first line of the code is missing a closing parenthesis. However, by passing a parameter, the callback will be executed immediately which leads to unexpected result.
You can try the following:
prez.startTimeline("Timeline 1", function () { Message("PlaybackFinishedMsg") } );
Hi, excellent! Exactly what I needed!
Thanks, Rolf
