Autofit symbol help
Hello Saola team, I need to know if there is a way to create a “symbol” that is completely autofit, I mean that it works like the “autofit” function of the main panel, but without activating that function… the entire site should be normal, but the autofit symbol
the canvas is set to % . Thank you very much in advance! It would be a great help if I could get a sample file! Thanks for the help as always
You can set up initially to achieve what you want.
Please try out our suggestions below:
  • Set up the default default symbol without AutoFit and the scene size of the symbol is 100%
If you want the symbol to fit with the content, you can convert the element to symbol > Edit symbol > select AutoFit checkbox at the Document pane.
After that, select all scenes > set up these scene sizes with px.
BR,
