Hi!
Currently, we can only export audio tracks one by one.
Would it be possible to export all the audio tracks as a final mixdown?
Thank you.
Hi!
Thank you.
You’re right, currently you can only export audio tracks one by one. So I think the workaround here is to join all the audio tracks into one and then export it as a single audio file:
Hope this helps!
Unfortunately, this only helps a little. It only works if the audio tracks are not overlapping. If they are, only two tracks are joined and the others are lost.
Another option I can suggest, though it takes a few extra steps is to export your entire project as a video, then import that video back into ActivePresenter and use Split Audio Track by right-clicking on the video object to separate the audio from it.
Thank you.
That’s exactly what I did. I exported the entire video and then used an advanced audio editor.
