You have in the past responded on how to hide and load a music file automatically with a scene by clearing Controls checkbox in Properties > General > Media to hide the audio and checking Autoplay.
How can I enable the music file to continue playing on the second and third scene. Movement from one scene to another is enabled by an Event Handler on buttons which trigger Next Scene or Scene 2_1.
After much trial and error, I have defined a few issues I am facing. The first 2 points works in Edge but not in Chrome (76) and Firefox
Audio isn’t playing across scenes – click blue button on Scene 1 to go to Scene 2 or 3 (I thought I had figured this out from this thread, but apparently not )
Audio doesn’t Autoplay in Chrome – need to click on screen to start it
How do you create a pause / play button? I have tried pause via the green button (per code in other thread on audio) – but it doesn’t Pause the audio. Also, how can I make the same button a Toggle switch for Pause and Play?
