In the current version, you can use Audio Normalization feature for each audio object in each slide separately. The steps can be performed like those in the video below:
We will consider updating this feature in the future if there are more request from users.
The Normalization button is greyed out for me. I am trying to normalize audio on a .mov file.
Is it possible to normalize the audio on a .mov file. I have the free version.
The Audio Normalization feature doesn’t work for .mov file.
So, if you want to enable this feature, please make sure to use audio objects. (MP3, OGG, WMA, and WAV)
When I record a new project then two big wav files are created, one from my microphone the other from PC sounds. And I think these files are used then in the project. My idea is to give the user an option to normalize the whole wav file.
Or are there any suggestions for third party tools to normalize the audio file outside ActivePresenter? And If I will do this outside ActivePresenter will AP use the modified file the same way as the original file?
It’s like shooting sparrows with cannons, but I haven’t found anything better. It would be nice if this could be done in the ActivePresenter without additional tools.
Maybe there are some simpler free tools to normalize the source audio files?
It seems that Audacity is the most suitable one for free and open source.
And if you normalize the audio file outside ActivePresenter then import that file to the app, your modified file now becomes the original file.
