I got an advanced action that consists of an audio + a javascript. if this action is triggered, the javascript runs smoothly but the audio is not played. If I have the same audio in the event that triggers the advanced action, the audio plays without any problem.
To sum up:
Advanced action (play audio 1 + Javascript) --> can’t hear audio.
play audio 1 + Advanced action (Javascript) --> I hear the audio.
We have checked but could not reproduce the issue. Could you please share the information about your browser? And share a sample file that has the problem so we can check? You can email it to support@atomisystems.com.
As I checked your project, the “ScheibenRotieren” advanced action that you are using doesn’t have audio in the Play Audio action, so please add audio to play.
Sorry for that! I added the Audio to the first advanced Action that popped up. I didn’t think that the other advanced Actions would still be in the Project after deleting all the other slides and shrinking the Project.
